I was attempting to run a HyperPixel4 with touch on a Pi 3 using latest Raspian Lite 2018-11-13. Ran the HyperPixel4 installer and display is working fine. Running in the default orientation. My problem is with touch. For some reason when I run EVTEST the X and Y maximum values are inverted. So on the longer X axis I get EVDEV events from 0-479 and on the shorter Y axis I get EVDEV events from 0-799. I would expect this to be reversed so the longer X axis was 0-799 and the shorter Y axis was 0-479
EVTest Output:
Input driver version is 1.0.1
Input device ID: bus 0x18 vendor 0x416 product 0x38f version 0x1060
Input device name: "Goodix Capacitive TouchScreen"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 125 (KEY_LEFTMETA)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 17
Min 0
Max 480
Event code 1 (ABS_Y)
Value 771
Min 0
Max 800
Event code 47 (ABS_MT_SLOT)
Value 0
Min 0
Max 4
Event code 48 (ABS_MT_TOUCH_MAJOR)
Value 0
Min 0
Max 255
Event code 50 (ABS_MT_WIDTH_MAJOR)
Value 0
Min 0
Max 255
Event code 53 (ABS_MT_POSITION_X)
Value 0
Min 0
Max 480
Event code 54 (ABS_MT_POSITION_Y)
Value 0
Min 0
Max 800
Event code 57 (ABS_MT_TRACKING_ID)
Value 0
Min 0
Max 65535
I tried the alternate drivers, with many combinations/switches when building, but still can’t get the expected results from EVDEV. Am I wrong in how I am expecting the EVDEV events to be reported? If not, is there some way to correct this?
