Hyperpixel4 Touch Raspberry Pi4
HEllo,
I have 2 problems :
My touch screen don’t working and impossible to turn the screen. I have a vertical screen.
Could you help me please ?
You have the touch version? I only ask because there is a touch and none touch version.
Instructions for rotating the display can be found here.
Thanx for this answer :)
I have the touch and i have the driver.
The display show information but impossible to rotate or use the touch
Ok, I don’t own a Hyperpixel so there isn’t much more I can do. There are some similar threads on this so if you do a forum search you may find an answer.
https://forums.pimoroni.com/search?q=hyperpixel%20rotate
I just try on Raspberry PI 3 and all is ok.
I only have a problem on Raspberry PI4
Are the Pi 3B and Pi 4B both running the same build of PiOS?
There was a new release of PiOS on Aug 20th. Which I think has a new kernel?
What happens if you put the SD card from the 3B into the 4B?
