Inky Frame build-in LED doesn't work?
I´m trying to blink the built-in LED of the raspberry pi pico W of the Pimoroni Inky Frame, however I don’t get it to work.
I am able to blink the CONN LED for instance, but not the built-in LED (Pin = 25)
from machine import Pin, Timer
bi_led = Pin(25, Pin.OUT)
timer = Timer()
def blink(timer):
      bi_led.toggle()
timer.init(freq=2.5, mode=Timer.PERIODIC, callback=blink)
blink(timer)
also efforts like:
bi_led.value(1)
did not work.
Just a heads up, what used to work with a Pico, doesn’t work on a Pico W.
Pico W onboard LED not working [SOLVED] - Raspberry Pi Forums
Thank you very much!!!
I modified my code. It works!
