Hello,
Up until two days ago everything was going swimmingly. I was using my new Inky Impressions eink 7.3 inch 2025 frame with no issues. I’m pretty new to python and I’ve been programming a simple image cycle program as well as quote/joke cycle programs. It has been fun learning using this tool.
Interfacing with the board I almost exclusively use the following lines of code:
from inky.auto import auto,
inky = auto(ask_user=True, verbose=True)
inky.set_image(resizedimage, saturation=0.7)
inky.show()
Up until the last two days I have had no issue uploading images to the screen. But all of a sudden I have not been able to interface with it.
Initially, I got the following terminal output when using the auto() recognise function:
warnings.warn(
Failed to detect an Inky board. Trying --type/–colour arguments instead…
usage: joke_display.py [-h] [–simulate] --type
{what,phat,phatssd1608,impressions,7colour,whatssd1683,impressions73,spectra13,spectra73}* -
[--colour {red,black,yellow}]*
joke_display.py: error: the following arguments are required: --type/-t
And when I try to us the inky.ac073tcla driver (from inky.inky_ac073tc1a import Inky) directly I get the following terminal output:
warnings.warn(
/home/allan/.virtualenvs/pimoroni/lib/python3.11/site-packages/inky/inky_ac073tc1a.py:224: UserWarning: SPI: Cannot disable chip-select!
- warnings.warn(“SPI: Cannot disable chip-select!”)*
/home/allan/.virtualenvs/pimoroni/lib/python3.11/site-packages/inky/inky_ac073tc1a.py:285: UserWarning: Busy Wait: Held high. Waiting for 1.00s - warnings.warn(“Busy Wait: Held high. Waiting for {:0.2f}s”.format(timeout))*
[1905:1905:0524/150247.946121:ERROR:components/dbus/xdg/request.cc:169] Request ended (non-user cancelled).
I have checked that both the i2c and SPI are enabled but with no change in function.
I can use both the button.py and led.py provided examples with no issue.
The quote I have been stuck looking at for the last two days, proof I did have this working prior to this issue:
Any help on this issue is appreciated. Not sure what to do from here.
Cheers,
Allan
