InkyFrame and Large Json Responses
I want to use the InkyFrame with the Pirate Weather API (Pirate Weather) . However, this returns a response of over 100K, which is too large to use with the json library as it loads everything into memory.
Can anybody suggest an alternative? My ideas so far are:
1.) Write a server to proxy the requests and compress them into a more sane format, maybe proto buffers or similar.
2.) Port json-stream to micropython. I hoped someone had done this but I can’t find it.
3.) Write my own hacky json parser
All of these are annoying and involve extra work. I’m hoping there’s a clever solution I’ve missed that just works.
Thanks,
Martin
Three more options:
  • ask Pirate Weather to extend the api (options to reduce the response-size to the needed)
  • use some other weather-api (e.g. meteo)
  • have a look at the circuitpython implementation of the json parser. Maybe porting this to micropython is less work than writing your own.
BTW: I went the route of your first option with a different project (calendar data). I lifted the complex processing of the caldav-api to a server and only return the necessary stuff to the InkyFrame for displaying it.
Thanks. It looks like the meteo API is much more concise and that might be the best option to start with.
Martin
