Got my inkyPhat a couple of weeks ago and was going though the tutorials and when I did the name badge example.
python name-badge.py --type "phat" --colour "red" --name "Inigo Montoya"
I get and error - "python: can’t open file ‘name-badge.py’ : [Errno 2] No such file or directory’
Not sure why.
Hi
Have you made sure you are in the right directory folder ?
From the terminal type: “ls” without the “ and it will show you the file in the directory, if name-badge.py does not show in the list then you will need to change directory.
Yeah, it sounds like the file isn’t in the folder your running your command from. its in a sub folder. Try cd phat then your above command.
