Is it possible to stack the following?
I would like to, inside a PiBow, stack a Pi 3B, Pi-DAC Pro and a HyperPixel. Will this be possible and if so might there be a cooling issue?
Thanks,
Bobb
If you check out Pinout.xyz it shows that HyperPixel uses pretty much all of the GPIO pins, so it’ll not work with the DAC Pro.
What he said, https://pinout.xyz/pinout/hyperpixel# I think your pretty well limited to one Hat if you use it.
You could potentially use a USB DAC alongside the HyperPixel as an alternative.
