The board looks great for my use case, but I’d like to be able to either move the LCD panel or break out a different display. How feasible is this? Thanks
The LCD that’s on it, is not intended to be removed or replaced with a different one. You could wire up an alternate SPI display. You would use the other “chip select” pin, the one not in use by the current display.
SPI at Raspberry Pi GPIO Pinout
