Hi, as a complete noob I’m just about to purchase and build my fist picade. Does it have a built in power on/off button as part of the kit to safely turn off the picade and raspberry? Thanks.
There is a soft power on off button on the Picade Hat. The board features a soft power switch that allows you turn your Pi on and off safely without risk of SD card corruption. Tap the connected button to start up, and press and hold it for 3 seconds to fully shutdown and disconnect power.
Sounds like it works the same way the on off shim does.
Thank you for your reply.
