Picade X hat power button
I have a Picade X hat and am planning to add a power button. I could not find the details about the type of button I have to use (push-button or on-off switch) and how to wire it. Can anyone provide me with this information? Thanks!
As far as I know its a momentary contact, normally open switch. Same as the arcade buttons but with a built in LED. Push to turn on, push again to turn off. And you don’t have to use the LED if you don’t want to.
There is a contact our support team link on the shop page if you want confirmation from Pimoroni staff.
This is the button we use: Metal Illuminated Button (Picade Power Button) - Pimoroni
And there’s info on how we wire it up in the Picade tute: Assembling your 8" or 10" Picade with PICO-8 (it plugs in to the terminals on the Picade X HAT marked Power ON and LED ON)
bit of an old thread, but maybe someone can help - i’ve got the on/off button working fine on my Picade X hat, but the LED is not very bright at all. Is there a way to increase the brightness of the LED in the power button?
Yeah, the LED in this button is fairly subtle when powered from the 3v3 on Picade X HAT.
16mm momentary buttons are pretty common and varied though, so you could try swapping in a different one. We used to use this one in Picade which I seem to remember had a brighter LED but was much less robust than the current metal one, which is why we swapped…
Thanks. The metal one does have a very nice ‘action’. :-)
