I finished the assembly of my 8" Picade with my Raspberry Pi 4B. All is well except the power switch LED will not light.
The switch shuts down and starts the Picade fine but won’t light. I have made sure all the terminals are correctly attached to the switch (red to + and black to -) and to the HAT (red connector in terminal closest to screen).
im having the same problem plus some more. The power button powers on the Picade. The LED does not light up and the PI is showing its ‘under powered’. I have a 5v adapter plugged in. Were you able to solve your problem?
On my system the LED connector on the X HAT is producing 2.7v. Maybe your X HAT is faulty?
Just to note that I’m using the previous version of the X HAT (micro USB powered) but I don’t think the voltage to the switch’s LED would be any different.
To chip in; I have the exact same issue (10", though that is negligible).
Though the instructions are not accurate, all other functionality is fine (exceptionally so, in fact) but I cannot get the switch LED to fire. It works to power on and shutdown the unit.
This is definitely not something ‘we’ are doing wrong…
It seems the light doesn’t come on immediately and is under software control. Mine never lit until I installed the required kernel module (as per the installation instructions).
