Just received another Pi Zero W, WiFi and Bluetooth not working
Hello,
I’ve just received my order (#PI211147) but there’s a problem with the Raspberry Pi Zero W - wifi and bluetooth are not working.
I have 4 x Raspberry Pi Zero, 2 x Raspberry Pi Zero W and 1x Raspberry Pi 3.
I just flashed a new 2017-07-05-raspbian-jessie-lite (dropping ssh and wpa_supplicant.conf to boot, like I always do for a headless setup) and the new Pi Zero W doesn’t show any wifi or bluetooth. Tried same card with the other W that I have and everything works ok. Tried on two other Pi Zeros with wifi dongle and everything works just fine.
The new W works fine with a wifi dongle, still bluetooth is not showing anywhere (listed as dead).
Thanks in advance
Hi there Trico,
Take a look at this post here and follow it through to see if you also have a dud Zero W: No Wifi/Bluetooth on Pi0W V1.1
If so, drop an email to support@pimoroni.com mentioning this post and they’ll sort out a replacement for you. :)
Thank you for your reply.
I’ve checked and it’s not a dud:
vcgencmd otp_dump:
30:009000c1
cat /proc/cpuinfo:
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 9000c1
Serial : 00000000665b4e72
In that case, it sounds like faulty hardware. Could you email support@pimoroni.com and we’ll get a new one sent out, please?
Will do.
Thank you for your support :)
Hello,
Just got my replacement, working perfectly :)
Thank you for your great support!
