Hi
Just finished assembling a Keybow 2040 that Santa kindly left under the tree for me.
All of the pre-installed examples are working fine, save for the two MIDI examples (midi-sequencer and midi-arp) both of which give the following error when running
RuntimeError: No pull up found on SDA or SCL; check your wiring
I had the same error on a PIco RGB keypad base that I bought a while ago and fixed by soldering a couple of resistors on the bottom, but I don’t fancy doing that to such a nice bit of kit as the Keybow.
Can anyone help getting the examples to run without any clunky hardware modifications?
David
