Hi All,
I’m looking for some assistance with the Keybow Mini programming.
I’m using a US keyboard in the uK and one application I use often has issues with the fact i have to use AltGr + hash to enter a Backslash, so i’m trying to porgram Keybow to enter it.
I’ve tried the following in Mini.lua:
function handle_minikey_02(pressed)
keybow.set_key("\", pressed)
if pressed then
keybow.set_pixel(2, 0, 0, 255)
else
keybow.set_pixel(2, 0, 0, 0)
end
end
but it doesn’t recognise the keypress. I’ve tried it without quotes too. Other regular keys work though so I know the Keybow mini is working
I then tried setting up a custom function key in keybow.lua
'keybow.BACKSLASH = 0X5c`
and then called the variable in mini.lua with:
function handle_minikey_01(pressed)
keybow.set_modifier(keybow.BACKSLASH, keybow.KEY_DOWN)
if pressed then
keybow.set_pixel(1, 0, 255, 0)
else
keybow.set_pixel(1, 0, 0, 0)
end
end
But it again didn’t enter anything.
I’m probably missing something easy, but appreciate any help.
Also, sorry for the oddly formatted code snippets, i’m not sure how to embed it and keepo the formatting. -Edit, I worked out how to embed the code snippets properly!
Thanks!
