I am playing around with the LTR559 connected to my Raspberry Pi Pico via the Explorer base. I am running version 0.2.2 of the Pimoroni Pico micro python library. My first port of call was to check out the example here and appears to build fine.
from breakout_ltr559 import BreakoutLTR559
PINS_BREAKOUT_GARDEN = {"sda": 4, "scl": 5}
PINS_PICO_EXPLORER = {"sda": 20, "scl": 21}
i2c = PimoroniI2C(**PINS_BREAKOUT_GARDEN)
ltr = BreakoutLTR559(i2c)
part_id = ltr.part_id()
print("Found LTR559. Part ID: 0x", '{:02x}'.format(part_id), sep="")
reading = ltr.get_reading()
if reading is not None:
print("Lux:", reading[BreakoutLTR559.LUX], "Prox:", reading[BreakoutLTR559.PROXIMITY])
time.sleep(0.1)
Nothing appears to happen for the first 12 seconds and then I see the following outputted until I stop the program.
No matter where I put the sensor, lux appears to always be 0 and the proximity is always 1457, even if I put something in front of it. It simply never changes.
What I was expecting was to see the values change if I move the sensor to a lighter environment and also see the proximity value change if I put something in front of it, but this appears to never happen.
I wanted to check to see if my understanding and expectations of the sensor are valid.
I have one, I used it with a Pi Zero. If I remember correctly the LUX value goes up in bright light and down in low light. The brighter the light the higher the number. And the proximity value increases as the detected object gets closer to the sensor.
It was easy enough to miss. I didn’t see it right away, I messed around for a while until the light came on. We won’t likely forget now though. I have a Breakout Garden Base on the way, to compliment my Explorer Base. I can see myself getting “momentarily” caught up once or twice forgetting to edit that line. ;)
