I’m sure this is superbasic, like me.
Working on a python script on a pi4 I find out the same script will run on one folder, but id copied to a different one it wont.
I know (very little but…) about enclosed environments. The script I mention is on a folder called python and there is no env source necessary to run it. It finds the libraries it needs to import and runs well.
When I move it to the folder I use for the project, based on a BME688, the program cant find the LCD1602 Module (the library, I guess as the LCD is plugged and work ready).
Any suggestions where I should be looking? How to make libraries available to all or particular folders?
This is the code the compiler returns whe the program is run on the main project forlder:
File "/home/fer/bme68x-python-library/examples/tests/forced_bsec_lcdDisplay.py", line 11, in <module>
import LCD1602
ModuleNotFoundError: No module named 'LCD1602'
Any pointers much appreciated.
