Hi, just installed a MOTE PHAT onto a raspberry pi zero running an “out of the box” copy of Pixel and launched the curl command as mentioned on the github link, but it fails with a compilation terminated error.
Does the curl command work with my hardware\OS version combination? I can get a copy of the full error message if required.
It’s hopefully a one-off… particularly as our libraries make their way into the Raspbian repo (so will automatically drag packages they depend on from there).
… but yes, it’s worth noting that a ‘fresh’ copy of Raspbian, even as recent as a few days is not necessarily up-to-date, I recommend running sudo apt-get upgrade right away after creating a SD.
