Unable to find Mote Device
Hi! I’m just setting up my Mote pHAT and have tried to run the test.py program but I’m getting the error “OSError: Unable to find Mote Device”.
I’m using a fresh install of Raspberry Pi OS on a Raspberry Pi 2 Model B with the Mote pHAT and just one Mote strip.
Some LEDs lit up on boot when I first plugged it in and a few times after. But now it’s now not lighting up at all. I’m thinking I may have broke it or something? But I have no idea how!
Any suggestions on what I could do to fix or at least figure out if it’s the hardware that’s broken would be greatly appreciated!
Just to double check, you did the,
curl https://get.pimoroni.com/motephat | bash
How are you running test.py, command line or from an IDE?
Yep done that. I get the same issue running via an IDE or the command line.
I currently have one rogue blue LED thats turned itself on so its definitely getting some sort of power…
Nevermind I’m an idiot…I did not realise there’s a Mote and a Motephat library I just skimmed over your answer and I’ve realised I downloaded the Mote one. Thank you so much!
Mistakes happen. Now you can have some fun.
