Mounting Pico RGB Keypad Base in Box
I would like to mount a Pico RGB Keypad Base within a laser cut plywood box, with the button expose. It appears the header on Pico RGB Keypad Base is preinstalled, which means I wouldn’t be able to install the Pico underneath the base. Is this correct?
That’s correct, the socket headers are preinstalled.
