Pi 400, stock no overclock.
Custom modified Pimorni pHat Stack that plugs directly into the Pi 400’s GPIO header.
Pimoorni Proto Zero with an RV3028 RTC and Trackball Breakout soldered to it.
Pimoorni Proto Zero with two SPI sockets setup side by side.
Two 1.54 Color SPI 240x240 LCD breakouts.
I borrowed the custom changes over time background code from an Enviro+ example. Strip that out for a simple background and the file gets a lot smaller.
#!/usr/bin/env python3
import os
import sys
import numpy
import colorsys
import psutil
import ST7789
import pytz
from PIL import Image, ImageDraw, ImageFont, ImageFilter
from fonts.ttf import RobotoMedium as UserFont
from pytz import timezone
from astral.geocoder import database, lookup
from astral.sun import sun
from datetime import datetime, timedelta
from os import popen
def calculate_y_pos(x, centre):
"""Calculates the y-coordinate on a parabolic curve, given x."""
centre = 80
y = 1 / centre * (x - centre) ** 2
return int(y)
def circle_coordinates(x, y, radius):
"""Calculates the bounds of a circle, given centre and radius."""
x1 = x - radius # Left
x2 = x + radius # Right
y1 = y - radius # Bottom
y2 = y + radius # Top
return (x1, y1, x2, y2)
def map_colour(x, centre, start_hue, end_hue, day):
"""Given an x coordinate and a centre point, a start and end hue (in degrees),
and a Boolean for day or night (day is True, night False), calculate a colour
hue representing the 'colour' of that time of day."""
start_hue = start_hue / 360 # Rescale to between 0 and 1
end_hue = end_hue / 360
sat = 1.0
# Dim the brightness as you move from the centre to the edges
val = 1 - (abs(centre - x) / (2 * centre))
# Ramp up towards centre, then back down
if x > centre:
x = (2 * centre) - x
# Calculate the hue
hue = start_hue + ((x / centre) * (end_hue - start_hue))
# At night, move towards purple/blue hues and reverse dimming
if not day:
hue = 1 - hue
val = 1 - val
r, g, b = [int(c * 255) for c in colorsys.hsv_to_rgb(hue, sat, val)]
return (r, g, b)
def x_from_sun_moon_time(progress, period, x_range):
"""Recalculate/rescale an amount of progress through a time period."""
x = int((progress / period) * x_range)
return x
def sun_moon_time(city_name, time_zone):
"""Calculate the progress through the current sun/moon period (i.e day or
night) from the last sunrise or sunset, given a datetime object 't'."""
city = lookup(city_name, database())
# Datetime objects for yesterday, today, tomorrow
utc = pytz.utc
utc_dt = datetime.now(tz=utc)
local_dt = utc_dt.astimezone(pytz.timezone(time_zone))
today = local_dt.date()
yesterday = today - timedelta(1)
tomorrow = today + timedelta(1)
# Sun objects for yesterday, today, tomorrow
sun_yesterday = sun(city.observer, date=yesterday)
sun_today = sun(city.observer, date=today)
sun_tomorrow = sun(city.observer, date=tomorrow)
# Work out sunset yesterday, sunrise/sunset today, and sunrise tomorrow
sunset_yesterday = sun_yesterday["sunset"]
sunrise_today = sun_today["sunrise"]
sunset_today = sun_today["sunset"]
sunrise_tomorrow = sun_tomorrow["sunrise"]
# Work out lengths of day or night period and progress through period
if sunrise_today < local_dt < sunset_today:
day = True
period = sunset_today - sunrise_today
# mid = sunrise_today + (period / 2)
progress = local_dt - sunrise_today
elif local_dt > sunset_today:
day = False
period = sunrise_tomorrow - sunset_today
# mid = sunset_today + (period / 2)
progress = local_dt - sunset_today
else:
day = False
period = sunrise_today - sunset_yesterday
# mid = sunset_yesterday + (period / 2)
progress = local_dt - sunset_yesterday
# Convert time deltas to seconds
progress = progress.total_seconds()
period = period.total_seconds()
return (progress, period, day, local_dt)
def draw_background_left(progress, period, day):
"""Given an amount of progress through the day or night, draw the
background colour and overlay a blurred sun/moon."""
# x-coordinate for sun/moon
x = x_from_sun_moon_time(progress, period, WIDTH)
# If it's day, then move right to left
if day:
x = WIDTH - x
# Calculate position on sun/moon's curve
centre = WIDTH / 2
y = calculate_y_pos(x, centre)
# Background colour
background_left = map_colour(x, 80, mid_hue, day_hue, day)
# New image for background colour
img_left = Image.new('RGBA', (WIDTH, HEIGHT), color=background_left)
# New image for sun/moon overlay
overlay = Image.new('RGBA', (WIDTH, HEIGHT), color=(0, 0, 0, 0))
overlay_draw = ImageDraw.Draw(overlay)
# Draw the sun/moon
circle = circle_coordinates(x, y, sun_radius)
overlay_draw.ellipse(circle, fill=(200, 200, 50, opacity))
# Overlay the sun/moon on the background as an alpha matte
composite_left = Image.alpha_composite(img_left, overlay).filter(ImageFilter.GaussianBlur(radius=blur))
return composite_left
def draw_background_right(progress, period, day):
if day:
x = WIDTH - x
centre = WIDTH / 2
# Background colour
background_right = map_colour(x, 80, mid_hue, day_hue, day)
img_right = Image.new('RGBA', (WIDTH, HEIGHT), color=background_right)
# Draw the sun/moon
composite_right = Image.alpha_composite(img_right, overlay).filter(ImageFilter.GaussianBlur(radius=blur))
return composite_right
def overlay_text_left(img_left, position, text, font, align_right=False, rectangle=False):
draw = ImageDraw.Draw(img_left)
w, h = font.getsize(text)
if align_right:
x, y = position
x -= w
position = (x, y)
if rectangle:
x += 1
y += 1
position = (x, y)
border = 1
rect = (x - border, y, x + w, y + h + border)
rect_img = Image.new('RGBA', (WIDTH, HEIGHT), color=(0, 0, 0, 0))
rect_draw = ImageDraw.Draw(rect_img)
rect_draw.rectangle(rect, (255, 255, 255))
rect_draw.text(position, text, font=font, fill=(0, 0, 0, 0))
img_left = Image.alpha_composite(img_left, rect_img)
else:
draw.text(position, text, font=font, fill=(255, 255, 255))
return img_left
def overlay_text_right(img_right, position, text, font, align_right=False, rectangle=False):
draw = ImageDraw.Draw(img_right)
if align_right:
x, y = position
x -= w
position = (x, y)
if rectangle:
x += 1
y += 1
position = (x, y)
border = 1
img_right = Image.alpha_composite(img_right, rect_img)
else:
return img_right
def get_cpu_temp():
with open("/sys/class/thermal/thermal_zone0/temp", "r") as f:
temp = f.read()
temp = int(temp) / 1000.0
return temp
cpu_temps = [get_cpu_temp()] * 5
# Initialise the left LCD
disp_left = ST7789.ST7789(
port=0,
cs=0,
dc=9,
#backlight=19,
rotation=90,
spi_speed_hz=80 * 1000 * 1000,
disp_left.begin()
# Initialise the right LCD
disp_right = ST7789.ST7789(
port=0,
cs=1,
dc=9,
#backlight=19,
rotation=90,
disp_right.begin()
WIDTH = 240
HEIGHT = 240
# The city and timezone that you want to display.
city_name = "Halifax"
time_zone = "Canada/Atlantic"
# Values that alter the look of the background
blur = 50
opacity = 125
mid_hue = 0
day_hue = 25
sun_radius = 50
# Fonts
font_sm = ImageFont.truetype(UserFont, 27)
font_md = ImageFont.truetype(UserFont, 38)
font_lg = ImageFont.truetype(UserFont, 55)
path = os.path.dirname(os.path.realpath(__file__))
progress, period, day, local_dt = sun_moon_time(city_name, time_zone)
background_left = draw_background_left(progress, period, day)
background_right = draw_background_right(progress, period, day)
date_string = local_dt.strftime("%B %-d")
time_string = local_dt.strftime("%-I:%M%p")
img_left = overlay_text_left(background_left, (60, 5), date_string, font_md)
img_left = overlay_text_left(img_left, (225, 50), time_string, font_lg, align_right=True)
img_left = overlay_text_left(img_left, (10, 120), ("CPU Temperature"), font_sm)
cpu_temp = get_cpu_temp()
temp_string = f"{cpu_temp:.0f}°C"
img_left = overlay_text_left(img_left, (180, 155), temp_string, font_lg, align_right=True)
img_right = overlay_text_right(background_right, (28, 15), ("CPU Frequency"), font_sm)
str=popen("vcgencmd measure_clock arm").read()
str = str[str.find("=")+1:-7]
freq_string = f"{str}mhz"
img_right = overlay_text_right(img_right, (233, 50), freq_string, font_lg, align_right=True)
img_right = overlay_text_right(img_right, (53, 120), ("CPU Usage"), font_sm)
str = psutil.cpu_percent()
usage_string = f"{str}%"
img_right = overlay_text_right(img_right, (195, 155), usage_string, font_lg, align_right=True)
# Display image
disp_left.display(img_left)
disp_right.display(img_right)
time.sleep(1)
sudp pip3 install st7789
sudo pip3 install pytz
sudo pip3 install astral
sudo pip3 install fonts
sudo pip3 install font-roboto
run crontab -e
add
@reboot python3 /home/pi/pi-info.py
