Just put the picade together and followed all instruction to the letter. My screen will NOT turn on. Anyone had that problem ?
Have you added hdmi_force_hotplug=1 to the /boot/config.txt file?
Yes it is all connected.
Any other ideas ?
What power supply are you using?
This is the correct fix.
Put your SD card into a computer and open up the config file and add the line
Right at the bottom and it will work
