N64 How to get the joystick and the buttons to work
Hello
I built my picade some days ago, and I loved it. It’s amazing. :)
Now I tried some N64 games with Retropie 4.02 and they work just fine. But only with my Xbox One Controller attached to the usb port.
Whatever I tried, I didn’t get the Picade Joystick and Butons to work.
Did anyone here yet solve this problem, or has some ideas? :)
Hi
My joystick and buttons work in the N64 emulator unfortunately I can’t remember if I needed to configure anything and I am not near the Picade until Friday so can’t check. This is on v3.8.1 so might not be relevant to v4.0.2
Cheers
Paul
Hi Paul
I’d be happy if you can check. :) Would be great to play Mario Kart 64 with the Picade joystick. :)
Thank you.
Martin
ok, I got it. Wooohooo!
I just needed to install an emulator which uses retroarch. And with this it worked.
Now I only need to find out how I can use the joystick as analogue stick and not as dpad. :)
Hi
Excellent enjoy Mario Kart.
Cheers
Paul
The second problem I solved too, and already played. :) Loved it! :)
Thank you Paul.
cheers
Martin
Can you tell us how you solved it?
Hello!
Of course.
To Play the N64-Games with the Picade Stick and buttons I installed Ir_Mupen64plus in the Retropie-Setup and set this as default emulator for the N64 roms.
To use the stick as analogue I edited this config file: /opt/retropie/configs/n64/retroarch.cfg
I copied the input section for player 1 from /opt/retropie/configs/all/retroarch.cfg into the n64-file. Then I switched the entries from the dpad to the analogue and left the dpad entries just with a “”. You just need to be carful to fill in the axis-entries correctly. But there’s a note which explains how to do it. If you want, I can post you my config file later, when I get home.
cheers
Martin
Any chance you could do a tutorial on how you did it as i am a newbee and would really could do with you help
Or even the config file would help
I tried your suggestion and I didn’t get it to work. Can you post your n64 retroarch.cfg
any Solution here for RetroPie 4.1 with Picade Joystick and N64 Emulator?
GreetZ
Joey
Hi, can anyone post an N64 config file for RetroPie 4.1?
Thanks from Germany
Joey
has no one a config File for N64 Picade Joystick?
Hi
Try here as this is where the Retropie developers are
Cheers
Paul
Sadly I ve the same issue with raspberry pi4 and retropie 4.6
I had the same problem on the newest 10" Picade and RetroPie 4.7.2
This solution works for me e.g. for Mario Kart in lr-mupen64plus and lr-mupen64plus-next
Connect to the “configs” Samba share and copy the complete content in the file retroarch.cfg in the n64 folder.
# Settings made here will only override settings in the global retroarch.cfg if placed above the #include line
input_remapping_directory = "/opt/retropie/configs/n64/"
# Two analog sticks (DualShock-esque).
# Bound as usual, however, if a real analog axis is bound,
# it can be read as a true analog.
# Positive X axis is right, Positive Y axis is down.
input_player1_l_x_plus = "right"
input_player1_l_x_minus = "left"
input_player1_l_y_plus = "down"
input_player1_l_y_minus = "up"
#include "/opt/retropie/configs/all/retroarch.cfg"
Hopefully this helps others facing the same problem.
Cheers
Marcus
Thanks dude, i do confirm, this configuration is fixing the issue!
Cheers!
Everything is inverted…
I understand how to access the mainframe etc, but I don’t know how to change the settings for individual emulators…
I’m a pro at inverted mario kart now (N64) 🤦‍♂️
The configuration is set up right, but I’m struggling to tweak my home build properly 😔
Any advice welcomed 🙏
thanks man. I got it to work with your help.
