NVMe Base
Hi all, I have a Pimoroni NVMe Base with a Kingston 500gb ssd . I run Home assistant on a Pi 5 with sd , when I try to change from save Data on sd to ssd then the system is crashing. I follow the instructions on the web side but is Ther something special if I run home assistant as os . Thanks for help
