Phat DAC no audio
I’m trying to get pHAT DAC to work on a raspberry pi zero w. I soldered it and ran
 curl -sS https://get.pimoroni.com/phatdac | bash.
On 2nd run(test) there is no sound. I tried the manual install aswell but same result. What should I do?
Also no sound with
 speaker-test -c 2 -t wav
pi@raspberrypi:~ $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
pi@raspberrypi:~ $ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_dac,
Default Audio Device
sysdefault:CARD=sndrpihifiberry
dmix:CARD=sndrpihifiberry,DEV=0
Direct sample mixing device
dsnoop:CARD=sndrpihifiberry,DEV=0
Direct sample snooping device
hw:CARD=sndrpihifiberry,DEV=0
Direct hardware device without any conversions
plughw:CARD=sndrpihifiberry,DEV=0
Hardware device with all software conversions
Soldering:
I had a phat dac where I can’t get any sound out of either. I was luckily able to exchange for another one and used the “lazy” method of soldering the new one and now the dac I have works great.
I hate to be the bearer of bad news, but you appear to have soldered the pHAT DAC to the Pi Zero upside-down.
Right-side top-wards it should look like this:
