Hello,
Can I please ask:
Is there any noticable difference in the signal quality between the two output options (RCA vs 3.5mm jack) ?
Can the two outputs be used at the same time ?
The reason I am asking is that I have a couple of “old-school” analogue VU meters and I am unsure of how to connect them. I am initially thinking of making 3 seperate connections
- Connect Phat DAC with amplifier (3.5mm jack to 3.5mm jack)
- Connect Phat DAC Right RCA channel to “right” VU meter (negative to negative, positive to positive)
- Connect Phat DAC Left RCA channel to “left” VU meter (negative to negative, positive to positive)
Will this work or is there a better way to do this?
