Hello Pimoroni,
I have little problem with my latest Pi3B. Wifi is not working at all. First thing i noticed when i turned on Pi for first time is that there is some barely there buzzing noise from area in between HDMI, micro usb and Display port.
I tried 3 different installation of raspbian that are working on my other Pi’s. As last resort i downloaded fresh latest image of raspbian and burned it on new micro SD. Still no Wifi and buzzing sound still there.
I plugged in USB wifi which is working out of the box.
pi@Rpi3B:~ $ sudo vcgencmd otp_dump
08:00000000
09:00000000
10:00000000
11:00000000
12:00000000
13:00000000
14:00000000
15:00000000
16:00280000
17:1020000a
18:1020000a
19:ffffffff
20:ffffffff
21:ffffffff
22:ffffffff
23:ffffffff
24:ffffffff
25:ffffffff
26:ffffffff
27:00002727
28:885207ea
29:77adf815
30:00a02082
31:00000000
32:00000000
33:00000000
34:00000000
35:00000000
36:00000000
37:00000000
38:00000000
39:00000000
40:00000000
41:00000000
42:00000000
43:00000000
44:00000000
45:00000000
46:00000000
47:00000000
48:00000000
49:00000000
50:00000000
51:00000000
52:00000000
53:00000000
54:00000000
55:00000000
56:00000000
57:00000000
58:00000000
59:00000000
60:00000000
61:00000000
62:00000000
63:00000000
64:00000000
65:00000000
66:00000000
pi@Rpi3B:~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2835
Revision : a02082
Serial : 00000000885207ea
Last part of of dmesg where i noticed errors. Same micro sd card on other Pi3B with working wifi does not produce these errors!
[ 1.747644] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[ 1.751079] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 1.751421] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.751494] systemd[1]: Starting Remote File Systems (Pre).
[ 1.866015] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.866030] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.869178] smsc95xx v1.0.5
[ 1.885482] fuse init (API version 7.26)
[ 1.920267] i2c /dev entries driver
[ 1.960074] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:52:07:ea
[ 2.055689] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 2.121423] systemd-udevd[139]: starting version 215
[ 2.187260] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8176
[ 2.187274] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.187282] usb 1-1.4: Product: 802.11n WLAN Adapter
[ 2.187289] usb 1-1.4: Manufacturer: Realtek
[ 2.187297] usb 1-1.4: SerialNumber: 00e04c000001
[ 2.776291] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.680448] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.065668] mmc1: error -110 whilst initialising SDIO card
[ 4.160228] systemd-journald[143]: Received request to flush runtime journal from PID 1
[ 5.015968] usbcore: registered new interface driver rtl8192cu
[ 5.920146] random: crng init done
[ 6.367549] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.632607] uart-pl011 3f201000.serial: no DMA platform data
[ 7.121841] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:167932k SSFS
[ 7.205616] mmc1: error -110 whilst initialising SDIO card
[ 7.298012] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 7.298263] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.744375] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 10.305609] mmc1: error -110 whilst initialising SDIO card
[ 13.405628] mmc1: error -110 whilst initialising SDIO card
[ 36.751286] Bluetooth: Core ver 2.22
[ 36.752074] NET: Registered protocol family 31
[ 36.752081] Bluetooth: HCI device and connection manager initialized
[ 36.752100] Bluetooth: HCI socket layer initialized
[ 36.752109] Bluetooth: L2CAP socket layer initialized
[ 36.752133] Bluetooth: SCO socket layer initialized
[ 36.767082] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 36.767089] Bluetooth: BNEP filters: protocol multicast
[ 36.767102] Bluetooth: BNEP socket layer initialized
I am wondering if i can do anything to fix this problem?!
