Pi Zero + HyperPixel 4: Framebuffer / Pygame
Hello
I’m trying to runPeppy player on Pi Zero + HyperPixel 4 touch screen.
Peppy player installation and configuration processes are good.
I run the HyperPixel 4 one-line installer but Pygame will not make a display.
Can you confirm if the screen/driver can work in the console mode with framebuffer?
Do you have any simple Pygame example running in console/framebuffer mod?
The player is using Pygame library which in turn is using framebuffer for drawing on screen:
https://github.com/project-owner/Peppy/ … g.py#L1284
For the touchscreen the player needs the device ‘/dev/input/touchscreen’:
https://github.com/project-owner/Peppy/ … g.py#L1291
Thank you your help would be greatly appreciated
