Pi Zero working normally, act led not lighting
Hello,
Just got another Pi Zero, already had two, and the act led is not lighting.
The Pi is working normally, fresh raspbian lite image.
Tried the sd card in another Pi and the act led is working as it should.
Tried with no devices attached, same problem.
Any ideas?
Thanks in advance.
Could you attach a picture of your soldering
Thank you for your reply.
I didn’t solder it, it’s one of those solderless headers, but I noticed the problem with the led before I fit it.
Hmm not sure what the problem is then @gadgetoid any ideas
No prob, thanks anyway.
of the Pi works otherwise I suspect it is either the ACT LED is either dead or misligned LED… can’t think of any other reason.
