For some days the Pi5 NVMe base worked fine with a Lexar NM710 SSD 1TB as boot volume.
I’ve forced a shutdown keeping pressed the power button (as at other times) but now, rebooting, I’m stuck at boot cycle because I get the error: “M.2 PCIe HAT not detected."
I’ve tried once removed the power to reconnect the flat flex cable, but it was well fixed and rebooting I get the same error.
If I insert an SD card the system starts from there.
If I move the SSD to an external USB case I can see the volumes.
Is it a base hardware failure?
I use it with an arch linux distro and the default behavior of double press is to logout. I used the long press when it wasn’t reachable in the network.
