I’m just wondering if anyone could help me I’m new to adding accessories to the Raspberry Pi
I’ve currently got a Raspberry Pi 3 and looking to buy a Sense Hat with a Pibow 3 coupe, but I’ve got a few questions.
Does the Sense Hat come with standoffs or will i need to purchase them, if so which ones?
From what I’ve seen the Sense Hat sits on top of the Pibow 3 Coupe, so with this in mind do i need a GPIO header, I’ve read were some people have suggested it, but i’m not 100% sure, as i won’t be adding anything else to the GPIO, and again i’m not sure on which GPIO headers to get.
The sense HAT does plug in fine when used with a PiBow coupe case, but the mini-joystick on the HAT is in a corner of the board which could really do with extra mechanical support.
Do you think you could come up with something? Maybe a nylon spacer to sit between the board and the case, along with some pins.
What do you think? I reckon there’d be a few takers.
We quite often use adhesive rubber feet for this purpose, do you think that might work?
I also tried some small double-sided nylon keyhole clips that popped into the top of the PiBow and into the mounting holes of a HAT, but I couldn’t find ones that were quite the right length.
