Hello, I recently purchased a Pico 2.0 display, however having plugged it in and running some code off Thonny nothing is showing up on the display. The led and the backlight are working but it seems like the only thing i can change is the brightness of the display. The pico 2 came pre soldered.
What uf2 file did you flash the Pico 2 with?
And just want to confirm its the Pico Display Pack 2.
Which examples did you run, and did you do the required edits?
If you have a Display Pack 2.0" or 2.8" use DISPLAY_PICO_DISPLAY_2 instead of DISPLAY_PICO_DISPLAY
