Pico Explorer breakout pinout
Maybe it’s me, but I can’t find any reference to which way round to plug breakouts into the slots on the Pico Explorer base. Should they be plugged in with the positive supply rail on the Pico side, or the other way round with the ground pin nearest the Pico? I see they are polarity protected, so I’d hope they would survive either way round, but I guess they’ll only work when plugged in correctly!
Simon
Component side facing you, + towards the Pico.
Is there a schematic for the pico explorer available?
There is a bit of a pinout on the product page. You can deduce most of it from that.
There is another thread on specifics that you might find if you search for it. They talk about where the buzzer is hooked up etc. I don’t remember the title though?
The two breakout slots use i2c (SCL, SDA, INT), and the screen uses SPI (MOSI, DC, SCLK, CS).
