I was experimenting with some boiler plate hello world python examples, found on Pimoroni GitHub. All worked fine until I changed font from bitmap8 to sans and tried to run it. Since then the display can only show the static noise you see in the image. Nothing else was changed in the code else than the font. I’ve tried to clear the display, and I can see that it flashes in an attempt to clear itself but it ends up with same noise. I’ve also tried to set it back to bitmap8 but it doesn’t help either.
Anyone ever had this problem? Any idea where the error might lie? I haven’t attached the code because I’m currently away, but I assume it’s not the code since it’s a hello world script with template code from the GitHub.
