My code.py is where the original was, in the root directory.
Thonny shows the following in Shell
Adafruit CircuitPython 6.3.0 on 2021-06-01; Raspberry Pi Pico with rp2040
Its set to CircuitPython Generic.
ctrl c ctrl d gets me this
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
Traceback (most recent call last):
File "code.py", line 16, in <module>
File "/lib/keybow_hardware/pim551.py", line 22, in __init__
RuntimeError: No pull up found on SDA or SCL; check your wiring
Code done running.
Press Ctrl-C to enter the REPL. Use CTRL-D to reload.
I’ve only tried the one example.
EDIT: Found this, not sure what it means exactly? 4:30 AM here though and only just got up, lol.
Pico RGB Keypad i2c pullup error - Discussion / Raspberry Pi - Pimoroni Buccaneers
