Firstly thanks for the cool products.
So I am playing with the Pico Wireless Pack using the pimoroni-pico-v0.3.2-micropython-v1.17.uf2
My base idea is to call a REST API and based on the json response do something. I used the pico wireless examples to build my initial code using code from ppwhttp.py
In general the code works, I can read the json and get what I want but I have one main issue. The following code can hang
picowireless.get_data_buf(client_sock)
I can’t seem to recover from it. I used the http_request function as the framework for my code from the example in file ppwhttp.py, so it can be used as reference in the GITHub exmaple - https://github.com/pimoroni/pimoroni-pico/tree/main/micropython/examples/pico_wireless
Secondly, the size returned from the avail_data call seems less than expected. The code as per exampe:
while True: if time.ticks_ms() - t_start > timeout: picowireless.client_stop(client_sock) print("HTTP request to {}:{} timed out...".format(host_address, port)) return False avail_length = picowireless.avail_data(client_sock) if avail_length > 0: break print("Got response: {} bytes".format(avail_length))
And the response is:
Got response: 1369 bytes
But if I use the example code to fetch the data, my response is incomplete. I get the full header but partial body. The code in the example is (which I don’t use) is:
response = b"" while len(response) < avail_length: data = picowireless.get_data_buf(client_sock) response += data
So I ended up just pulling data until it breaks to get the full response (response body 397 bytes)
response = b"" while True: try: data = picowireless.get_data_buf(client_sock) response += data except: break
Now as mentioned above, this works in most cases, and I have the full connections checks in place as per the example in ppwhttp.py but ocasionally, and this may be on the REST side, the picowireless.get_data_buf(client_sock) call just hangs.
My question: Is there any better way to check for hung/timeout on this call? Also if this method is bad, how do I get the correct length from picowireless.avail_data(client_sock) to ensure I read the correct length?
Thanks,
