Picodisplay games
Are there any picodisplay games that work with the pimoroni firmware. all the games i have found use the old code import pico display
i have already found the tank game that works
Is there a way or converting old games that use import pico display to the import pico graphics code
First you’d have to change the import pico display to
from picographics import PicoGraphics, DISPLAY_PICO_DISPLAY
display = PicoGraphics(display=DISPLAY_PICO_DISPLAY)
or DISPLAY_PICO_DISPLAY_2 if its the bigger display pack.
Then see if you get any errors, if so sort out that referenced code.
got some old game working by reverting older firmware
Put this together last week for CamJam. Very basic and just uses the built in buttons. No extra parts needed.
# Display2 MAZE
# For 240x320 pixel display - for CamJam Nov 23
# Tony Goodhew 24 November 2023
from machine import Pin
import picoexplorer as display
import random, math, time
from picographics import PicoGraphics, DISPLAY_PICO_DISPLAY_2, PEN_RGB565
from pimoroni import RGBLED
display = PicoGraphics(display=DISPLAY_PICO_DISPLAY_2, pen_type=PEN_RGB565, rotate=0)
display.set_backlight(0.8)
display.set_font("bitmap8")
led = RGBLED(6, 7, 8)
width, height = display.get_bounds()
WHITE = display.create_pen(255,255,255)
YELLOW = display.create_pen(200,200,0)
GREEN = display.create_pen(0,200,0)
BLUE = display.create_pen(0,0,200)
RED = display.create_pen(200,0,0)
def sq(xx,yy,s,c): # Draws a filled square
    display.set_pen(c)
    for y in range(s):
        for x in range(s):
            display.pixel(xx+x,yy+y)
led.set_rgb(0,0,0)   # Turn off the RGB LED
display.set_pen(BLACK)
display.clear()
display.update()
display.set_pen(GREEN)
display.text("MAZE", 100, 80, scale=5)
display.set_pen(RED)
display.text("Tony Goodhew", 100, 180, scale=2)
display.update()
time.sleep(2)
display.clear()
KEY_UP = Pin(12,Pin.IN,Pin.PULL_UP)
KEY_DOWN = Pin(13,Pin.IN,Pin.PULL_UP)
KEY_LEFT= Pin(14,Pin.IN,Pin.PULL_UP)
KEY_RIGHT= Pin(15,Pin.IN,Pin.PULL_UP)
grid =[1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,
       1,0,0,0,1,1,0,0,1,1,0,0,1,0,0,1,0,0,0,1,
       1,0,1,0,0,0,1,0,0,1,0,0,1,0,1,1,0,1,0,1,
       1,0,0,1,0,0,1,0,0,0,0,1,0,0,0,1,0,0,0,1,
       1,1,0,0,1,0,0,0,0,1,0,0,1,1,0,0,0,1,0,1,
       1,0,1,0,0,1,0,0,1,0,1,0,0,0,0,1,0,1,1,1,
       1,0,0,0,0,0,0,0,0,0,0,0,1,0,1,0,0,0,0,1,
       1,0,1,1,1,0,1,0,0,0,1,0,0,0,0,1,0,1,0,1,
       1,0,0,0,0,0,1,0,1,0,0,1,0,0,0,0,0,1,0,1,
       1,1,1,1,0,1,0,0,0,0,0,0,1,1,0,1,0,0,0,1,
       1,0,0,0,0,0,0,0,0,1,1,1,1,0,0,1,0,1,0,1,
       1,0,0,0,0,0,1,0,1,0,1,0,0,0,1,1,0,1,1,1,
       1,0,1,0,1,0,0,0,0,0,0,0,1,0,0,1,0,1,0,1,
       1,0,0,1,0,0,0,1,0,0,0,0,0,0,0,1,0,0,0,1,
       1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1]
def update(): # Draw the grid
    p = 0
    for y in range(15):
        for x in range(20):
            if grid[p] == 1:
                sq(x*16,y*16,16,BLUE)
            p = p + 1
    display.update()
start = time.ticks_ms() # Start timing
for q in range(2):  # Target counter
    datahx = [1,18] # Starting positions
    datahy = [1,13]
    datatx = [18,2]
    dataty = [1,13]
    x = datahx[q]  # Hunter
    y = datahy[q]
    tx = datatx[q] # Target
    ty = dataty[q]
    update()
    display.update()
    sq(x*16,y*16,16,YELLOW) # Draw hunter
    sq(tx*16,ty*16,16,RED) # Draw target
    update()
    display.update()
    # ==== INNER LOOP =========
    running = True
    while(running):
        key_flag=1    # Button pressed?
        if(key_flag and (KEY_UP.value()==0 or KEY_DOWN.value()==0 \
        or KEY_LEFT.value()==0 or KEY_RIGHT.value()==0 )):
            time.sleep(0.05) # Debounce delay
            key_flag=0
            m = x # Store current coordinates of hunter
            n = y
            # Get new hunter position from buttons
            if(KEY_UP.value() == 0) and (grid[x+20*(y-1)] == 0):   # UP
                y=y-1   # Calculate new position
                if(y<0):
                    y=0
            if(KEY_DOWN.value() == 0) and (grid[x+20*(y+1)] == 0): # DOWN
                y=y+1
                if(y>14):
                    y=14
            if(KEY_LEFT.value() == 0) and (grid[x+20*y -1] == 0):  # Left
                x=x-1
                if(x<0):
                    x=0
            if(KEY_RIGHT.value() == 0) and (grid[x+20*y +1] == 0): # Right
                x=x+1
                if(x>19):
                    x=19
            sq(m*16,n*16,16,BLACK)  # Remove old position
            sq(x*16,y*16,16,YELLOW) # Draw new position
            if (tx == x) and (ty == y):  # Caught the target!
                stop = time.ticks_ms()   # Get current time since start
                sq(tx*16,ty*16,16,GREEN) # Colour target green
                display.update()         # Show green target
                time.sleep(1.0)          # Wait a moment
                sq(tx*16,ty*16,16,BLACK) # Remove old target
                running = False          # Stop inner looping - new target
        display.update()  # Update the screen
# Show time taken
secs = (stop - start)/1000.0
print(secs)
display.clear()
display.update()
ss = str(secs)
display.text("TIME:", 100, 60, scale=5)
display.set_pen(YELLOW)
display.text(ss, 100, 120, scale=5)
display.update()
A button joystick instead of the buttons makes it easier to control.
works great thanks
r
