I have been experimenting with the 5x5 matrix breakout and seem to have discovered that one of the LEDs is not being driven properly.
Here is the matrix with the affected element having its red LED driven at full intensity (255) while the red, green and blue LEDs of the other elements are being driven at one seventeenth of full intensity (15):
Initially, I thought I had made a programming error, since I am not using the Python library directly, but once I had corrected a mistake in enabling the LEDs (which actually affected the problematic LED and two neighbours), I found that the LED concerned would not work correctly. I think that its neighbour on the bottom row might occasionally have problems, too.
Is this a recognised issue with these boards? I will endeavour to look further into this, just to rule out other causes.
I’m not aware of this being a recognised PIM435 fault. Since green and blue on the same pixel work and only red is weak, I’d first suspect a damaged red die or a local solder/contact problem rather than the driver code. The occasional neighbour issue is the more telling symptom: it hints at a marginal connection around that part of the board. Running the same driving setup on a second breakout would quickly separate a board fault from your setup; if it follows the board, ask Pimoroni about a replacement.
I contacted support, and Pimoroni are going to send a replacement. If they want to inspect the board, they may certainly do so, but I will definitely be double-checking my own work, too. Well, probably at least triple-checking by that point.
It must be said that the LEDs certainly perform when they do perform!
I had a similar issue with a Unicorn Hat. I had one lone Red segment that wouldn’t light up. Pimoroni sent me a replacement with no fuse. A little while after that I treated myself to a hot air reflow / soldering station. A careful application of some hot air to reflow the solder connections fixed the defective LED. Bonus. =)
