Pimaroni NVMe BASE Duo with Pi5
  1. I have pimaroni NVMe base duo. it doesnt show up no matter what i do on configs or installs or cable setup or SSD changes.
  2. I have a pimaroni NVMe BASE - that works fine 100%, shows up and even in the SSD works.
  3. I have also RaspberryPi PCIe M.2 HAT - this also works with Hailo card and SSD as well.
It appears the NVMe BASE DUO I have is a broken one. and its the first time I connected it! How can i get it fixed / replaced.
I have done tons of hours of - Pi 5 image reinstalls, configs of dtparam dtoverlay, reconecting cables, etc but of no use.
RB
Drop our support team a message with some photos of your setup and as much info as you can about what’s not working and what you’ve tried to get it working and they should be able to help.
