Pimoroni Trackball PIM447 issues: won’t work as mouse
Hi there!
Got a neat Pimoroni trackball, but having trouble with some of the github code supporting it.
I can get some of the py examples to work (rainbow, colour-control) just fine, but the ones that are really important such as mouse.py (xte not found) and evdev-mouse.py (no module named ‘evdev’) don’t work.
I’m using Raspbian as recommended, trying to make the trackball work as a mouse. Unfortunately the documentation is pretty much inexistent, thus there’s not much I can do without your help. :)
Any hint or tip of where I should start to make it work?
Cheers!
Did you do the?
You must:
sudo modprobe uinput
sudo cp 10-trackball.rules /etc/udev/rules.d/
sudo udevadm control --reload-rules
And run this script as root with:
sudo ./evdev-mouse.py
Yep, as instructed. I get the error ‘no module named evdev’
Is there a driver for it or just the python programs?
Ok, wasn’t sure if you had seen that message in the file.
I don’t have that trackball. One issue is it uses i2c instead of the USB bus. That makes it tricky to use as a mouse etc. At least I would think so.
The last time I used evdev I was following this tutorial. Might help, not sure?
https://learn.pimoroni.com/tutorial/robots/controlling-your-robot-wireless-keyboard
Also found this,
https://python-evdev.readthedocs.io/en/latest/
Right, the issue was indeed missing installation of Python evdev (for evdev-mouse.py) and xautomation (for mouse.py), none of which are installed by default nor are covered in the documentation on github (which is pretty flimsy, to be candid).
I’ll open a github ticket on the project hoping this gets added/explained, the package could really do with some love on the docs side. ;)
Glad you figured it out. Bummer when some instructions are missing etc though.
