Pin details for pico inky pack
I’m trying to combine a pico inky pack with a few other sensors. My code works well when my pico w is directly connected to the pico inky.
I tried wiring up the required pins (display pins only, so no buttons or the reset for now) by following my understanding of the schematic, that is:
36, 31, 27, 26, 25, 24, 22, 21
I tried wiring a few different grounds across as well.
I’m using the pico breadboard kit from pi hut for the time being.
Anyway, I was hoping to confirm that my pins are wrong and I’ve misunderstood the schematic, so if someone could confirm which pins are in use that’d be great!
Thanks!
Rob.
Ah, this is a stupid one! :-) turns out I did understand the pins correctly but with the pico the other way up the connections to the pins on the inky pack are mirrored! It’s working now
