Pirate Audio - ST7789 Image Display Breaks Audio
I’ve also been experimenting with the pirate audio board - in my case the one with a built in speaker - and seem to have quite a bit working with it.
I can’t find a way to attach a file to this forum, so here is a (fairly large for a forum post) chunk which gives prerequisites, setup and code to use the buttons to do different things with the screen and speaker.
Perhaps let me know if it all works for you, and if it seems OK I’ll try to get it added to the git repo for the pHat.
#================================PREREQUISITES===============================
# I started with Raspbian Lite - bigger versions of Raspbian should be fine
# Ensure that the file at /boot/config.txt cobntains these two lines:
#		dtoverlay=hifiberry-dac
#		gpio=25=op,dh
# and put a hash before this line (as shown) to disable it:
#		#dtparam=audio=on
#  You need to install software and libraries as follows:
#		sudo apt-get update
#		sudo apt-get install python-rpi.gpio python-spidev python-pip python-pil python-numpy sox libsox-fmt-mp3
#		sudo pip install st7789
#  The code below also assumes that you have
#	- an mp3 file called 'test.mp3' in the same folder as the program (see lines 140 and 144 of this file)
#	- a font file at /usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf (see lines 70-73)
#  You can of course change thes locations within the code on the lines shown above.
#=========================END OF PREREQUISITES===============================
#================================BASIC SETUP=================================
#Library imports
# imports for screen
# documentation for PIL is at https://pillow.readthedocs.io/en/stable/reference/index.html
from PIL import Image
from PIL import ImageDraw
from PIL import ImageFont
from ST7789 import ST7789
#import os for beep
import os
#imports for buttons
import signal
import RPi.GPIO as GPIO
#import time so we can make a puase
# Set up the screen and image buffers
#Set up screen
SPI_SPEED_MHZ = 80
screen = ST7789(
    rotation=90,  # Needed to display the right way up on Pirate Audio
    port=0,       # SPI port
    cs=1,         # SPI port Chip-select channel
    dc=9,         # BCM pin used for data/command
    backlight=13,
    spi_speed_hz=SPI_SPEED_MHZ * 1000 * 1000
# screen size details
width = screen.width
height = screen.height
# Create a few blank images.
# This lets us set up layouts/pictures, then send them easily to the acreen
# We set up an array of images and a corresponding array of draw objects, one for each image
image = [None] * 4
draw = [None] * 4
for i in range(4):
	image[i] = Image.new("RGB", (240, 240), (0, 0, 0))
	draw[i] = ImageDraw.Draw(image[i])
# Set up a font to use when showing text
# I've shown how to create two different sizes
# You need a font file in the appropriate directory.
# If using Raspbian lite, you'll need to create the directory and get a font from (eg) https://www.fontsquirrel.com/
font30 = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf", 30)
font60 = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf", 60)
# Create a 'beep' function - a simple noise to make sure sound is working at any stage
def beep():
	beepcmd = "play -n synth 0.3 sine A 2>/dev/null"
	os.system(beepcmd)
# Set up the basics for buttons
# The buttons on Pirate Audio are connected to pins 5, 6, 16 and 20
BUTTONS = [5, 6, 16, 20]
# These correspond to buttons A, B, X and Y respectively
LABELS = ['A', 'B', 'X', 'Y']
# Set up RPi.GPIO with the "BCM" numbering scheme
GPIO.setmode(GPIO.BCM)
# Buttons connect to ground when pressed, so we should set them up
# with a "PULL UP", which weakly pulls the input signal to 3.3V.
GPIO.setup(BUTTONS, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# NB: Further down, we'll set up the button handler which will tell teh pi what to do on each button pressed
#================================END OF THE BASIC SETUP======================
# Set up our actual images
# image 0 should already be a black screen as that's how we set them all up.  It's useful when we end the program
# image 1: get pi logo.  raspberrypi.png should be a 240x240 image in the same directory as the program
image[1] =Image.open("raspberrypi.png")
# image 2: draw a multicoloured series of small boxes over the display.
# This uses the 'draw' object associated with image3
#draw.rectangle ((x0,y0,x1,y1),(r,g,b)) draws a box from x1,y1 to x2,y2, using r,g,b as colour values
for row in range(10):
        for cell in range(10):
                draw[2].rectangle((cell*24,row*24,cell*24+24,row*24+24), (cell*25, row*25, 0))
#image 3 uses drawing text to put a menu item next to each button
# let's have a function to do the repettitive stuff
def show_text(draw, message, x, y, font, ralign):
	size_x, size_y = draw.textsize(message, font)
	text_y = y - size_y
	text_x = x
	if ralign:
		text_x = x - size_x
	draw.text((text_x, text_y), message, font=font, fill=(255, 255, 255))
show_text(draw[3],"play", 0, 90, font30, False)
show_text(draw[3],"logo", 0, 200, font30, False)
show_text(draw[3],"colours", 240, 90, font30, True)
show_text(draw[3],"exit", 240, 200, font30, True)
# Set up the button handler
def handle_button(pin):
	label = LABELS[BUTTONS.index(pin)]
	print("Button press detected on pin: {} label: {}".format(pin, label))
	if label=='A':
		# button A - play the sound file, suppressing output by sending it to /dev/null
		# You'll need a file called 'test.mp3' in the same directory as the program
		# Show the blank image while the file is playing - this could be a different image, of course
		# NB: Showing the blank screen doesn't actually prevent button presses being made and stacked up
		screen.display(image[0])
		os.system("play test.mp3 2>/dev/null")
		screen.display(image[3])
	if label=='B':
		# button B - show the logo image, and pause for a second
		screen.display(image[1])
		time.sleep(1)
	if label=='X':
		# button X - show the colour image, and pause for a second
		screen.display(image[2])
		time.sleep(1)
	if label=='Y':
		# button Y - show the blank image, and exit
		GPIO.cleanup()
		exit()
# Loop through out buttons and attach the "handle_button" function to each
# We're watching the "FALLING" edge (transition from 3.3V to Ground) and
# picking a generous bouncetime of 100ms to smooth out button presses.
for pin in BUTTONS:
    GPIO.add_event_detect(pin, GPIO.FALLING, handle_button, bouncetime=300)
# Now that we are all set up, show the menu screen (image 3)
# Finally, since button handlers don't require a "while True" loop,
# we pause the script to prevent it exiting immediately.
signal.pause()
[end of code]
