I made my animation software public on GitLab: Plasma 2350 W loop animation · GitLab
It’s a first setup, maybe it will inspire others.
I like the idea and I have done quite some similar animations using Pimoroni’s encoder wheel. Animations kick in when there is some “thinking”, “pausing”, “configuring”, or just to bridge time for the user, etc.
I have an Encoder Wheel connected to my Plasma 2350. I have a 144 pixel RGB strip setup as my desktop lighting. I use the encoder wheel to adjust the color and brightness of the strip. I did have a couple of patterns setup but have since lost that file somehow? I had to start over with the Plasma 2350 when my plasma (2040) got fried by a power supply failure. Might have another look see for it. I think I’ll also look at my past posts to see if I posted.
Anyway, many thanks for the link to your code. I will play around with it at some point. =)
EDIT: found a copy of my old code that I posted here.
import plasma
import machine
import micropython
from plasma import plasma2040
from breakout_encoder_wheel import BreakoutEncoderWheel, UP, DOWN, LEFT, RIGHT, CENTRE, NUM_BUTTONS, NUM_LEDS
from pimoroni import RGBLED
led = RGBLED(16, 17, 18)
led.set_rgb(0, 0, 0)
user_button = machine.Pin(22, machine.Pin.IN)
a_button = machine.Pin(12, machine.Pin.IN, machine.Pin.PULL_UP)
BUTTON_NAMES = ["Up", "Down", "Left", "Right", "Centre"]
i2c = PimoroniI2C(20, 21)
wheel = BreakoutEncoderWheel(i2c)
last_pressed = [False] * NUM_BUTTONS
STRIP_LEDS = 144
SPEED = 20
UPDATES = 60
# WS2812 / NeoPixel™ LEDs
led_strip = plasma.WS2812(STRIP_LEDS, 0, 0, plasma2040.DAT, color_order=plasma.COLOR_ORDER_GRB)
led_strip.start()
offset = 0.0
brightness = (0.5)
pattern = 0
red = (1 / 360)
green = (130 / 360)
blue = (250 / 360)
yellow = (60 / 360)
orange = (30 / 360)
white = (1.0)
# Read all of the encoder wheel's buttons
for b in range(NUM_BUTTONS):
pressed[b] = wheel.pressed(b)
if pressed[b] != last_pressed[b]:
print(BUTTON_NAMES[b], "Pressed" if pressed[b] else "Released")
last_pressed[b] = pressed[b]
if pressed[UP]:
pattern = 0
wheel.clear()
for i in range(NUM_LEDS):
wheel.set_hsv(i, 1, 0, brightness)
for s in range(STRIP_LEDS):
led_strip.set_hsv(s, 1, 0, brightness)
wheel.set_hsv(0, 1.0, 0, 1.0)
wheel.set_hsv(6, blue, 1.0, 1.0)
wheel.set_hsv(11, blue, 1.0, 1.0)
wheel.set_hsv(12, green, 1.0, 1.0)
wheel.set_hsv(13, red, 1.0, 1.0)
wheel.set_hsv(18, red, 1.0, 1.0)
color = white
if pressed[RIGHT]:
pattern = 0
wheel.clear()
wheel.set_hsv(i, blue, 1.0, brightness)
led_strip.set_hsv(s, blue, 1.0, brightness)
color = blue
if pressed[DOWN]:
pattern = 1
wheel.clear()
wheel.set_hsv(i, green, 1.0, brightness)
led_strip.set_hsv(s, green, 1.0, brightness)
if pressed[LEFT]:
pattern = 0
wheel.clear()
wheel.set_hsv(i, red, 1.0, brightness)
led_strip.set_hsv(s, red, 1.0, brightness)
color = red
if pressed[CENTRE]:
pattern = 0
wheel.clear()
led_strip.set_hsv(s, 0, 0, 0)
# Has the dial been turned since the last time we checked?
change = wheel.delta()
if change != 0:
# Print out the direction the dial was turned, and the count
if change > 0:
print("Clockwise, Count =", wheel.count())
else:
print("Counter Clockwise, Count =", wheel.count())
position = wheel.count()
brightness = ((position + 25) / 50)
if brightness < 0:
brightness = 0
if brightness > 1:
brightness = 1
print ("Brightness =", brightness)
wheel.clear()
if pattern == 0:
if color == white:
wheel.set_hsv(i, 1.0, 0, brightness)
led_strip.set_hsv(s, 1.0, 0, brightness)
else:
wheel.set_hsv(i, color, 1.0, brightness)
led_strip.set_hsv(s, color, 1.0, brightness)
if pattern == 1:
SPEED = min(255, max(1, SPEED))
offset += float(SPEED) / 2000.0
offset %= 1
hue = (offset + float(s) / STRIP_LEDS) % 1
led_strip.set_hsv(s, hue + offset, 1.0, brightness)
wheel.set_hsv(i, hue + offset, 1.0, brightness)
time.sleep(1.0 / UPDATES)
wheel.show()
thanks for searching and sharing
It was nice not to have to start over. Also going to give @PimoPete code a try on a spare plasma stick I have.
Wireless Plasma Kit (Pico W Aboard)
I made an update. Improved code and animations structure (Scene Class).
Busy with adding more animations.
