Hey all,
I’ve been playing with my picade + plasma led buttons and have started a project to generate led animations.
Plasmaburn is a library at the moment that will generate the PNG files to be used by the plasmactl tool
I have put together a sample/demo pack:
Download the zip on your picade to install a selection of demo/sample images:
wget https://plasmaburn.thef.uk/test-plasmaburn.zip ;
unzip test-plasmaburn.zip ;
cd test-plasmaburn ;
sudo bash install.sh
This will install the demo patterns using plasmactl
It should load the test-card image. Compare the less on your picade with the pattern on the test card
If that all looks good, try running the demo:
bash demo.sh
If the test-card doesn’t match, plasmaburn can be re-configured to match your button positions and orientation.
Some features so far:
- Gamma correction for less (needs more work)
- Button/led orientation configuration
- Colour palette, RGB and HSV support
- Transitions using “adjust” and envelopes
- OpenSimplex noise to create random but looping patterns
- Button and led geometry for patterns with precise angles (please could someone give me button measurements)
This is very much a work in progress, I’m moving it up to GitHub
