Ran into some errors during the installation process and figured I’d share potential updates to the “Fitting Picade Plasma Buttons” guide page.
curl https://get.pimoroni.com/plasma | bash : Ran into several errors with python3-pip not being installed by default, and a png library being absent. After a few detours, I was able to get things properly installed, but without some knowledge in CI, it could be a major blocker for some.
sudo apt install -y python3-pipsudo apt install -y python3-png
plasmactl 0 255 255 : Throws errors, as the correct syntax (with the library as of writing this that installed) is:
plasmactl --colour 0 0 255. Without the--colour, the command will fail.
I have screenshots of the whole process, in case it helps refine the observations further.
