I am using the Raspberry Pi3 Model 3 V1.2 board and 7 inch display and when put in the case designed for that combo the display is upside down. I’ve found the procedure to modify the config.txt file by adding the line: lcd_rotate=2 but I am not able to do any changes to that file. I’m locked out of changing anything concerning that file.
How can I get around making the needed change so I can get the display to be correct?
I found some info on this text editor and added the line to the file at the
bottom. Managed to save it with the ctrl+X command and save it. Now the
display is coming up correctly so thanks for the help in getting this issue
corrected.
