Recently I purchased a DVB-T Dongle ideal for ADS-B (real-time plane tracking)! intending to use it with one of my R-pi devices.
Initially plugged it in to my Nexus 7 tablet and the app ADS-B Flights Scanner detected it immediately.
Used device with TVHeadend to receive TV programs, no problems but now it won’t show on my Nexus 7 - reports No USB device attached. If I then unplug the tuner I then get another message saying the same.
I suspect using it for TV has altered the default 1090mhz setting.
Have you any advice how to reset this to 1090mhz ?
Hi Geffers,
I´m sorry, I can´t help solving your problem, but your setup sounds interresting. Could you please tell me which app you´re using?
Thank you.
Greetings
Kalle
P.S.: For help it may be important , to know which DVB-T dongle you are using.
The device was purchased to monitor aircraft and when plugged into my Nexus 7 worked immediately for aircraft monitoring using the app from Play Store ADS-B Flights Scanner.
Then used it on my Raspberry Pi using TVHeadend and TV programs work fine, as they do using VLC on a conventional computer.
