Hello. I’d like to propose a set_gamma() method on the scrollphathd object. I’m experimenting with different gammas and will eventually need to set a gamma on a finished project. If/when I upgrade to a new version of the library, I’d like to be able to continue using my code without re-hacking the library code. What are your thoughts?
I’ve also made a change to the number ‘4’ (code point 0x34) in the 5x5 font that I’d like to propose for inclusion. Is there a formal submission process or something I do on github or …?
Thanks, Mark
EDIT: I see there IS a set_gamma() method on the matrix object but I get “AttributeError: ‘module’ object has no attribute ‘set_gamma’” when I use it on the scrollphathd object.
Thanks, to both of you. I look forward to the next release and appreciate the EXTREMELY fast turn-around on this request. In the mean time, since I’m making a clock, I’ve created a fontclock.py file that I’m tweaking so I don’t change the standard one. If, in the end, it looks worthwhile, I’ll submit it to Github.
