Hi, I just purchased the Servo2040 board, and I’ve been looking for a pinout reference sheet to explain the pins on the opposite side of the servo headers. In particular what are A0, A1, and A2. Are these 3 analog inputs in addition to the 6 next to the LEDs? What is SWC and SWD?
Also, why didn’t these pins come with headers soldered?
Thanks.
OK, if your external supply is 5V, you don’t need to cut the jumper.
That external 5V will power everything, if you don’t cut the jumper.
It will also try to back power through the USB port.
You will need a Data only USB cable.
I ran into a similar issue on my Interstate 75. The Pico Power Supply wasn’t enough, current wise to drive my 64 x 64 LED matrix. I needed an external supply and wanted it to run the works. I have a USB cable that I cut the +5V wire on. I program it with that custom cable.
If your external supply is higher than +5V you need to cut the jumper to prevent damage to the RP2040 etc.
If you cut the jumper the external supply only powers the servo’s.
You will need to power the Servo 2040 via the USB port.
No need for a custom USB cable, for programing.
That helps alot to understand it. So, if I use an external 7.4v lipo, and I cut the jumper, the servos will be powered but nothing will happen because the Servo2040 board will not be powered?
I guess for a wireless solution, you will need a buck converter to step the voltage down to 5v, then feed this into the USB-C?
In this video https://youtu.be/OQ4Wjgn8A78?t=321 you can cut the trace and power the terminals with 5v. So, looking at the back of the Servo2040, which one is 5V and which is ground?
But according to this video https://youtu.be/OQ4Wjgn8A78?t=321 after you cut the trace, you can power the terminals with 5v instead of using the USB-C port…
I was wondering which terminal is which. So, looking at the back of the Servo2040, which one is 5V and which is ground?
I mean the part that you break on the back. It will leave 2 seperate traces when you break it. According to the video you can power that with 5V,.or am I misinterpreting what he said?
Ok, I’m going to rehash this a bit. You have IMHO misunderstood some of that video.
As is without the trace cut, the Servos and the Servo2040 both get +5V from the USB jack. If you only have a couple of servos connected this should be fine.
Or alternately, you can feed in +5V via the screw terminals and power both the Servo 2040 and the Servos. You do this if you need more current than the UBC jack can supply. You don’t need to cut the trace if your using a 5V power supply. It will back feed through the USB jack though. A Data only USB cable should be used.
If you do decide to cut the trace, you need to do the following.
Power the Servo2040 via the USB Jack. And power the Servos via the Terminal Block.
A normal USB cable is used for programing and power to the Servo2040.
Ok, I got it. So, with the trace uncut, you can only supply 5V max to the terminal screws? If you supply more than 5V to the terminal screws, you will need to cut the trace?
Appreciate the help alphanumeric, but I have just 1 more question. When you cut the trace and are using 7.4v or 11.1V on the terminal, and you have programmed the robot and want it to be free from the computer, is there another way to power the board other than the USB-C port? Is there a way to power it via the headers somehow?
That I don’t know.
As far as the Pico goes if your powering it via VSYS, 3.3v is fine.
You’d have to check the schematic to see what the 5v feeds other than the servos.
