Setting I2C address for Pan Tilt Hat
Is there a way I can set the I2C address for the pan tilt hat? I’m not finding it anywhere.
Pinout.xyz says that the address is 0x15. I don’t think you can set that manually though, it’s usually hard-set, or if it’s technically possible to change it can be a pain. Is there a reason you need to change it?
Usually, if its changeable, that’s mentioned in the product description. And there would be a jumper on the board. I don’t think that’s an option on the Pan Tilt.
My address for the hat is automatically set at x70
Do you have a conflict?
The problem turned out to be the pi wasn’t sensing it. It’s ok fixed now.
Good stuff, thanks for posting that you fixed it.
