Hi
I have just upgraded from a Pi4 to a Pi5 to use primarily for amateur radio.
I have just connected the Pi5 to a new monitor and I can only see the bootloader, how do I get the Raspian homescreen?
What version of Raspbian? The Pi 5 won’t boot from anything earlier than Bookworm.
It is possible, if not supported, to run bullseye on a Pi5, according to a Pi engineer
https://forums.raspberrypi.com/viewtopic.php?t=357737#p2157448
Pretty annoying that Pi5 was launched as bookworm only!
I only know of Raspian which I had with the Pi4. Any homescreen will do instead of bootloader which is purely comuter text.
I think your going to have to do a rpi-update on the Pi 4. then swap that SD card to the Pi 5?
Is it not possible to download whatever the new operation system is for the Pi5 onto a USB drive and load onto the Pi5 to overwrite the SD Card?
